trailgator bar in our stridas?
Hello everyone,
I have three years old twins and we would like to go out the whole family with our bikes.
We have seen the trailgator bar (probikeshop.es/images/produc … xation.jpg) can not put in the strida … do you?
Has anyone been able to mount this bar in some way or a similar contraption?
THX!!
PD: sorry for my english, google translate :smiley:
Hello jaitower,
no reason to be sorry - guess many of us can’t write perfect English :smiley:
Your request seems quite comprehensible, just…I’d not recommend to use these constructions combined with a Strida.
A few thoughts about the part:
  • Obviously it is made of steel; that means you must bend the clamps (a lot!) to get them over the seat tube.
    Once bent back and tightened will the harder steel most likely leave deep marks in the softer tube; perhaps damage it finally.
  • The angle of the clamps, related to the “kid connector”, doesn’t match to the angle of the Strida seat tube.
    So, the clamp mechanism has to be modified anyway.
Generally:
  • The frame geometry and the wheel diameters of full size bike and Strida are much too different, their constructions can’t be compared.
    I think it’s not assured that a mechanism like that will work without any (security?) issue on a Strida - just because it’s safe to use with full size bikes.
  • Simply imagine a triangle made of metal tubes; the corners shall be stiff like bone.
    Three tube triangles - and in sum nine tubes, all their corners welded tightly together will create (in principle) a common Diamond bike frame.
    Now consider that a Strida frame are just three tubes - and none of their joints is in fact fixed!
    All three connections are moveable in at least one direction!
    One must not expect a strong frame - when the joints are loose.
Sorry - not feeling able to help in this matter - perhaps I’m getting old and thinking too much about safety…
Finally best wishes for your double sweethearts
Yours sincerely,
thanks for your answer, chris
your advices are always welcome
I do not know how old you are (I have 35 years), but I also believe that safety is the first and foremost when it comes to my lovesss :smiley:
Well…take it as the meaning of Grandpa - 50 years on the planet and five years Strida forensic may have left some minor defects
Most likely I’d choose this in your special situation; foldable + full size combined:
http://dahon.com/mainnav/folding-bikes/single-view/bike/espresso_d21-1.html
I fully agree with Chris: a trail gator would put a lot of stress on the tiny Strida frame.
On top of that, I’m afraid the ride would not be very stable: the Strida has very little weight on the front wheel and the steering behavior is quite nervous.
I can already imagine what would happen if your kid starts to move sideways on his bike… :confused:
Follow Chris’ advice and go for a full size folding bike.
