Strida Evo rider report - London, UK
The place to report and discuss your experiences of owning and riding the Strida. Perhaps your first impressions, or your story of a big trip.
Postby StridaEvo-London on Sat Sep 22, 2012 5:02 pm
By request here is my rider report for the Strida Evo
Some observations Total real bike weight: 13.3kg (including 33cl of water)
My modifications
new saddle, grips and tyres.
I have added extra weight added by the Brooks flyer special at 810grams, stock saddle although comfortable it doesn't match the comfort of a Brooks saddle that really moulds to your shape.
My longest single ride at 32kms was a pleasant experience and easily completed.
I used the middle gear ratio (100%) most of the time, for hills the first gear at (78.7%) has been very well conceived and very effective. Riding on the flat the (125.7%) really makes this bike faster than a 3 speed Brompton (thanks to a good friend and Brompton owner).
My normal commute at 5 miles in London traffic (8.04kms) has reduced by nearly 5 minutes using the SX to 25 minutes, so average speed on the Evo 19.3kmh up from (16.09kmh on the SX).
I have just fitted Schwalbe Kojak and dropped the Innova stock tyres as these faster and lighter and reducing the overall bike total back to 13kg even with the addition of the brooks saddle. So highly recommended but also handling is much better.
The gears changes smoothly but I did notice the same sensation as highlighted from (keps) when peddling in low and high gears initially but this has dissipated with use so this is down to running the bike in.
The Evo is an evolution of the Strida design making it fully developed we have all requested and waited for the extra gears so now its here....But I do sometimes miss the simple SX because of the weight, no gears making this a perfect urban bike (Mark Sanders was right) but in this ever changing world we are now working more and faster the Evo reflects this....
My negatives for the Evo is the extra weight which is a trade off of the gears, and changing my riding style. Now at stops and red lights I would always lead off on the right side peddle by braking and peddling backwards to position myself for when the light turns green...of course with the Evo it changes the gears so I have occasionally tried to peddle off in the high gear!!
Overall the Evo is highly recommended what should Ming do to develop the model..? my vote is for making it lighter...anyone else???
StridaEvo-London
Re: Strida Evo rider report - London, UK
Postby Blackstridaaustria on Sat Sep 22, 2012 5:22 pm
Indeed interesting and highly appreciated - thank you very much! :D
StridaEvo-London wrote:The gears changes smoothly but I did notice the same sensation as highlighted from (keps) when peddling in low and high gears initially but this has dissipated with use so this is down to running the bike in.
Please may I ask how many kilometres (approx.) were needed for the running-in process?
STV@gmx.org
StridaTuningVienna
Postby StridaEvo-London on Sat Sep 22, 2012 5:37 pm
I only noticed this when I changed shoes to a thin sole and I could feel a slight roughness in the sensation through the peddles in the low and high gear but after a +100kms it has become smoother...but you have to search for it as it is very slight..So those thinking of purchasing an Evo should not be put off by this at all.
StridaEvo-London
Postby Blackstridaaustria on Sat Sep 22, 2012 5:48 pm
Thanks again, hopefully keps' drive will also work correct after a while...keep fingers crossed!
STV@gmx.org
StridaTuningVienna
Postby fwd-bwd on Thu Sep 27, 2012 10:43 pm
Most gear hubs need time to run in. What you are experiencing is likely normal. Thanks for the detailed report!
fwd-bwd
Postby blue on Fri Oct 12, 2012 11:40 am
Hi
could you please advise me where did you buy your Schwalbe Kojak tyres for the strida?
are they the same surface as a roadbike type of tyres? I am new to strida, I goet my evo last month.
what type of saddle did you change to?
they sound like good improvements could you share the information?
blue
Postby Blackstridaaustria on Sun Oct 14, 2012 3:37 pm
Hi blue,
blue wrote:...are they the same surface as a roadbike type of tyres?
http://www.schwalbetires.com/node/3530
http://www.schwalbetires.com/dealers?id=139
blue wrote:what type of saddle did you change to?
StridaEvo-London wrote:Brooks flyer special at 810grams
If the weight is correct it should mean "Brooks Flyer S Special",
according to the Brooks-site the "Flyer Special" is more heavy - 890 g.
Brooksengland/Flyer S Special
Brooksengland/Flyer Special
Brooks dealer locator USA
stridaforum/more comfy saddle
stridaforum/Brooks flyer
stridaforum/Replacing your seat?
BSA
STV@gmx.org
StridaTuningVienna
Postby Guess on Fri Oct 19, 2012 8:28 am
Hi StridaEvo-London,
I just want to ask if what to expect in the package when you buy your EVO, i do know that it will be different per distributor, but atleast i know what to look for. :-)
I want one as well, but i would like to know if the gear box for the transmition contains any plastic materials or is it pure steel or alloy like material instead? :-)
Does the freewheel, chain and crank set are all alloy? :-)
Maybe I dont tried my best to search the web for the answer to my questions, but any response would be appreciated.
I'm new on this STRIDA world. ;-)
Guess
Postby StridaEvo-London on Sun Oct 21, 2012 11:49 am
Well I don't think the differences will be that great, stock standard model is 18inch wheels, alloy freewheel, crank set is not alloy.
My mods seat and kojak tyres are additional and down to personal preference.
As for the transmission I cannot say how what materials it contains.
StridaEvo-London
Postby ulrico on Sun Oct 21, 2012 10:14 pm
Just a quick note that I'm also part of the London Strida Evo riders - matte black.
ulrico
Postby Guess on Mon Oct 22, 2012 8:39 am
StridaEvo-London wrote:Well I don't think the differences will be that great, stock standard model is 18inch wheels, alloy freewheel, crank set is not alloy.
Thanks so much for your response StridaEvo-London. :-) Hoping i can join the EVO bandwagon soon. :-)
Guess
Postby Blackstridaaustria on Mon Oct 22, 2012 12:07 pm
Hello ulrico,
...and thanks for registering! :wink:
STV@gmx.org
StridaTuningVienna
Postby Guess on Thu Oct 25, 2012 5:20 am
ulrico wrote:Just a quick note that I'm also part of the London Strida Evo riders - matte black.
Hi ulrico,
How's your EVO riding? :-)
Guess
Postby Tom_T on Fri Nov 30, 2012 12:31 pm
Good review thanks for posting :D
Tom_T
Postby deepfraught on Sun Dec 30, 2012 1:19 pm
I got my Strida Evo a few days ago, Australian version black with neon yellow down tube, as a late xmas present to self to scrape in on bikes for 2012, moratorium on n+1 new bikes for 2013 is one of my new year's resolutions =P
Like OP's report, my first test up hills of local street a few times I didn't notice difference through 1,2,3 but wasn't looking for it, just a feel for the ratios and speed. I definitely don't regret paying the weight penalty for the gears.
Here it is in a badly stitched panoramic photo of my 'little wheel crowd'
Like most first ride impressions coming from regular bikes, short wheelbase twitchy steering, I feel the desire for some short bull horn bar ends for some finer control, being used to much wider bars on other bkes. I really like the sequential gears, sister rigid "lefty" to my hooligan, "righty" rear, use of bearings instead of bushes, really everything about it (honeymoon phase).
Ours already comes with 1.35in Kojaks on it, bonus for the month was a bike bag included, no immediate need for me but I'm sure I'll find a use for it in the future.
deepfraught
Next
Return to Riders Reports
Users browsing this forum: No registered users and 4 guests
