Was about to buy an EVO, would love a C1 but it has no gearing & for a hard rider, I need gears.
Own a couple of SX’s, true racing Stridas but for the gears.
Reluctant to invest $1300 for an EVO, then $200 in pedal upgrades, etc.
Was searching on craigslist for used stridas and found a link for ebay stidas and then speed drives/gearing.
Which one would you guys recommend, they are Taiwanese but say they are the same German engineering?
Do I need to replace more than just the $280 components?
Is it complicated, could a bike store do it or do they need specialized tools & parts?
Here they are, all 3 seem slightly different;
This one is for $280
ebay.com/itm/Schlumpf-Speed- … SwCQNWf4v7
This is for $400 but seems to have a whole lot more
ebay.com/itm/Schlumpf-Speed- … SwmrlUugHw
This one is for $480 but it talks about an ebike application
ebay.com/itm/Schlumpf-Speed- … 1491338172
Has anyone had any recent experience with these companies?
Does it make that much of a difference, having a second gear?
What are the real advantages?
Correct would be Suisse engineering, btw…
“… as an enthusiastic owner of a Strida 5.2 I would be highly interested in where to get a speed drive and in knowing the costs of the precious piece. Sharp, possibly not really competent, tongues here in Austria claim the Strida MAS (=ATS drive) does not operate properly.”
“The sharp tongues are not totally wrong: years ago we made a licence agreement with a Taiwanese company.
Presently, these gear drives are mounted into the Stridas - unfortunately with little success since the quality leaves a lot to be desired. For this reason we decided to produce a tailor-made alternative including the excentric fitting for the Strida, which is now available and works faultlessly. However, with “made in Switzerland” and 5 years full warranty this part is also a little more expensive.”
From here:
Re: Has anyone retrofitted a schlumpf on their strida?
If you mean your first two links:
They seem to be complete, but without tools.
The third link is a longer version which is not suitable for Strida (no beltwheel, no belt, no eccentric bottom bracket).
I’ve done a lot of work just to help Strida riders to judge about this delicate and personal question.
Nobody else than YOU can tell if it will be complicated for YOU.
An experienced shop must be able to do; they will already own most of the required tools.
Just a short, not productive mail contact with bikegang.
My opinion telegram style:
One gear - much too less.
Two gears, heel gear shift - cool, but still too less.
Three gears, backwards pedaling gear shift - not my style, well, Ok…
Seven gears - now we’re talking
Shifting by heel kick during pedaling forwards .
As always, a fantastic answer from Blackstridaaustria!
While I can do almost anything, it seems;
At $400 for a Taiwanese kit
Without buying the specialised tools
Then the Labour costs
It’s much cheaper to buy an EVO.
Moreover after reading what the inventor suggests, deep in those threads, about $650 plus, it makes even less sense.
THANK YOU!
