It’s Grace from OneMotor. Just wanted to let you know that we finished development and testing of our new Strida mount for OneMotor. Here’s a link to pics and a vid clip:
This mount will fit any wheel size Strida (the 16" or the 18" or even anything in between), is installed to the Strida frame using only two clamp straps, and is made from ultra-strong Nylon that won’t scratch the frame.
Once the mount is attached, then the OneMotor can be installed or removed in under 10 seconds, so you can easily use a single OneMotor on multiple Stridas or multiple bikes interchangeably (and even multiple scooters) . Most importantly, the OneMotor can remain installed on the Strida without interfering with the fold in any way.
Note that both OneMotor battery pack sizes (the Compact and the Extended) will fit in the seat tube location shown between the seat and the rack for a nice, clean install that still allows you to use the rack for carrying things.
We hope you like this solution! Please feel free to post any questions here or directly via email to: info@onemotor.co
I only find a few links when I search for 'Strida Mini 4.1". And it looks substantially the same as the regular Strida.
Is there any difference to the frame tubing or wheels or pedal / crank / belt layout? As long as that’s all the same, then our mount should fit it.
If you can direct me to some specific links or photos to confirm, please do so and I’ll take a look!
Thanks!
Hi Chris,
Hope you’re well too!
Thanks for posting the link.
Based on that list, the two items below are the relevant ones in determining if the OneMotor Strida mount fits as-is:
Frame is different . Not just the size but also the weldings.
Here the important thing is that the ‘s-curve’ that is above the rear wheel is the same shape, as the OneMotor mount clamps onto this, and the mount is designed to EXACTLY fit that curve (we 3D-scanned it with a high-end scanner)
Wheel size is different(14 vs 16 or 18).
Here the 14" wheel size would mean that the sliding adjustability of the OneMotor mount would need to be able to slide far enough ‘downwards’ to reach the 14-in tire. Unless of course the frame of the mini positions the wheel closer to the ‘s-curve’ where the OneMotor mount sits, which seems more likely if they have a separate frame design for this bike…
So my hunch is that there’s a good chance it’ll fit, with the shape of the S-curve being the most important factor to check!
