I previously replaced the rear brake cable on my Strida.
I have since replaced the front brake cable as well and it was very difficult. It was on Christmas day last year that I did it and I drew pictures explaining this today and I will ask questions about this work.
First, when I tried to pull that front brake cable out, the outer housing seemed to break in this position. (Actually, it may have ruptured when I pulled it out)
Therefore, all of these outer housings and inner wires had to be pulled out.
I then tried to insert the new brake cable into the front tube, but I could not insert the cable beyond this 90-degree bend in the front tube, and I had to remove a part in this area to continue the process.
I used a flathead screwdriver and pliers to remove this part, but I scratched this part.
I had to remove this part and manipulate the cable through the open hole as if I were a surgeon. This was also very difficult.
Then, after much effort, I was able to get the cable to penetrate to the wheel, but had a very difficult time getting the brake cable outward through the hole in the front tube. I worked on this for a long time and finally managed to get it out.
I cannot put thin pliers into this hole, nor can i use tweezers or other tools to grab the brake cable in the hole. In fact, I don’t remember how I took it out anymore.
The Strida manual states that the front brake cable should be inserted from the bottom up, and I tried to do it from that direction, but I just couldn’t get through the 90 degree bend in the front tube this way.
The brake cables will surely break if the Strida has been driven for several years. Therefore, if there is no mechanic nearby who is familiar with Strida, these tasks should have to be done by the owner at some point.
Is there an easier way to perform these tasks? I am particularly interested in the following two points
- Is there any good way to remove part 215-15 without damaging it?
- Is there some means or tool suitable for comfortably extracting the brake cable through the small hole in the Strida tube?
I will try to use these tools next time I do this work. (I don’t hold out much hope, as I have made and used one similar to this wire, but could not successfully get the brake wire out)
https://www.amazon.co.jp/dp/B07MVC9MX5?language=en_US
