Just wondering if anyone has thought about a more comfortable ride using Schwalbe ballon tires. The Schwalbe website promotes them extensively, says they add a lot of comfort, roll easily and are used on several Dahon folders.
Has anyone out there tried ballon tires on their Strida? If so, could you reply with your experience. Wondering if they fit the bike ok without removing the fenders, and if the bike folds with no problem with the fatter tires.
Advantage: lightweight, low rolling resistance due to high pressure (5,0 - 8,0 bar) and no profile, no need to watch the mounting direction, room saving spare tyre for longer rides (foldability)
Disadvantage: less comfortable due to high pressure, less traction on wet or sandy roads, not suitable for cobble stones or hardpack gravel
The Kojak is my favourite tyre - high speed with less effort
I’d recommend not to ride Kojak’s without carrying pump and tyre repair kit, small spiky stones may cause flats.
Kojak’s are mentioned at several posts, please find also more opinions via the forum search (49 matches)
